Mike
A while back, I had a brand new battery that sat for a long time, eventually
loosing its charge. It was slow-charged for several hours until the battery
voltage read ~ 12/12.5 volts. I was actually having problems with the
battery handling a load; cranking for 4-5 seconds revealed a slow-down on
the starter. I proceeded to do a gravity test, which the battery failed. I
brought the battery into Sears where they put the battery on some
cutting-edge technology machine that didn't use gravity testing. I was
actually arguing with the manager because he was telling me that gravity
tests are very inaccurate. How can this be? Battery acid has greater gravity
than plain water, which makes up most of the fluid in a dead battery, thus
causing the "balls" to drop in the tube. This was a while ago, but the
thought just popped in my head...
