Hello,
I have been wandering for the past two days on Ebay trying to figure out what would be fit for my hobby in matters of welding. I only need to weld tiny spots, like on jewellery or batteries. But there are a few Chinese-made machines that drew up my attention:
1. 1,3KW / 3,2KW / 4,3KW machines that sell at around 100-300USD, some of which come with welding pen attached to the base unit. Their power is ranked in terms of KW, although it is stated that they can only weld up to 0.3mm nickel sheets.
(https://www.ebay.com/itm/4-3KW-Spot...023926?hash=item5b7fda1a36:g:TB8AAOSwwqBfkA20)
2. 200W / 400W/ ....4000+W machines that sell at relatively higher prices. They are updated with argon channels and are usually more expensive than the previous category. No problem until now, but the description states that they can weld from 0.3mm up. How can they weld a higher width material than the previous category, if the WATTS are lower???
(https://www.ebay.com/itm/Pulse-Argo...774108&hash=item2f155ce333:g:EQQAAOSwj1hae-Ai)
3. 30 A / 50A / 100A / 150A machines that seem to be the most expensive, but which are attached with seemingly lower WATTS power, yet they are advertised to achieve the most satisfactory results... for example 100W:
(https://www.hajettool.com/Pulse-Spot-Welders/150a-argon-arc-spot-welder.html)
4. Finally, there are machines listed with their voltage power, but this is not so important for me right now, since they are scarce and I imagine it is some sort of advertising scheme.
Can someone please help me elucidate this mistery: Which machine is the best to acquire for jewellery welding of tiny spots? Which is the link between AMPS, WATTS and VOLTS (and I mean the deeper meaning, because I have already understood the hydraulic analogy...). The reason why I am asking these stupid questions resides in the fact that the machines with power rated from 1.3 to 4.3KW achieved low results up to 0.3mm metal sheet, while the machines rated with 200-400W could acquire more powerful crafts....
