Hi all,
I was trying to find the difference of wavelength of 868MHz compared to 928MHz.
Using a online calculator i found that the wavelength if 868MHz is 34.5cm and 928MHz is 33cm.
If i wanted to use a printed antenna, would i simply make the length of the track 33cm? What hapoens to matching components for 50R matchibg, will they change for a 928MHz compared to 868MHz? Finally, please could you explain what quarter wavelength means with resoect to 33cm, is it 33cm/4? Why is this important?
Thanks in advance.
Thanks in advance.
