kuba said:
Hmm... I don't quite understand. Could you please explain it one more
time for me? I understood, that I must cover tips of connector with
tin solder. It's impossible to do this, because I work in very big
factory, and we cannot make this with each connector
(( I know, that
we should buy special PCB carriers, but money money money....
What he means (I think) is that some components should be hand soldered (after
wave soldering) to prevent them being moved in the wave solder process.
In order to do this you need to 'mask' the holes they fit into during wave
soldering with a compound he calls 'solder mask'. After wave soldering this must
be removed before it cures like an adhesive becomes tough to remove.
And yes. It costs MONEY and TIME to do the job right. If you want to save money
and do the job BADLY, that is your (actually the management's) decision. This is
why it's important to have good competent managers. An incompetent manager may
find a way to do the job on the CHEAP but it will never be a job done WELL.
Of course the reason you have about these issues is because clearly your
management IS incompetent or this problem would never have happened in the first
place. Sadly, today, most management is incompetent in my experience. The bosses
just want a 'yes man' more than they want a man who knows what he's talking
about.
Graham
