Platforms
Content
This is not a good analogy.If you imagine water flowing as the voltage, think of the amount of bubbles being the current, more bubbles more current more voltage faster the water flow
No. water flow is current not voltage. what causes the water to flow "pressure" can be compared to voltage.If you imagine water flowing as the voltage,
Current is movement of charge. Charge is measured in Coulombs. A movement 1 Coulomb of charge per second is 1 Amp, which is the measure of current.
Voltage is measured between two places. It tells you how much energy an charge gains or loses when moving from point A to point B. It is measured in Volts. A volt is the potential difference that would result in 1 Joule of energy being used to move 1 Coulomb of charge between the two points.
Power is energy consumed per second. Power is measured in Joules / second or Watts. So if 1 Coulomb of charge is moving through a potential difference of 1V every second, the power is 1 Watt. In other words, power is voltage times current.
Bob
Electricity and water don't mix too well.I once heard all these terms be likened to a water pipe with water flowing inside it. Can anyone tell me which parts are which?
Do hydraulic engineers study electrical circuits to understand hydraulics? If not, they why are you studying hydraulics to understand electrical circuits? Why confuse things with a mind melt of the two subjects. Each field of study is its own thing. What concept about circuits is it that you need to jump to another field to understand?Here is the site I found that on. Is this a good analogy?
http://science.howstuffworks.com/environmental/energy/question501.htm
It is basically wrong and confusing. For instance, voltage (joules/coulomb) is not equivalent to pressure (newtons/meter^2). What is there about electrical units that you do not understand?Yes, I uderstand that the water analogy is basic, but that's what I want is a basic answer.
