John Fields
i don't think that would work anyhow - the 4538 triggers on a rising edge
of the output of the 'or' gate between inputs A and B. This will let you
trigger on either a rising or falling edge, by choosing which input to
connect the trigger signal to and using the other to gate it with. but i
couldn't see any way of triggering on both edges using just one 4538.
You can do it by holding the inactive (at the moment) input at the
level it needs to be at to allow the other input to trigger. Look at
the truth table; it's all there.
Also check "Watering controller 4" on
alt.binaries.schematics.electronic for a four-chip solution that
should give you everything you want, including a two hour holdoff
timer.
_____
BTW, your 4538 RESET inputs are shown floating last time I looked at
your schematic. Not good; they need to be tied high if you're not
using them. Also, there's no such thing as a 340K pot, you don't have
the "B" sections of the comparator and the one-shot pinned out
properly, and I think you're going to run into leakage current
problems with that 1000µF cap. Plus, how about if you knock off that
annoying little passive-aggressive trick of not using upper-case "I"'s
where you should?
