Paul Burridge said:
Hi guys,
I've seen a lot of stuff on the net about Spice modelling that takes
into account paractics at RF, but they typically turn out to be....
-----inductor-----resistor------inductor--------
-----cap-----|
Definitive resistor model... Hmmmm. Sorry I have to preach...
In the far back of your mind do remember that all discrete component
models are themselves approximations of Maxwell's equations based on
the assumption of "lumped equivalence". Lumped equivalence says that
if the physical dimensions of your circuit and/or components are far
smaller the shortest relevant signal wavelength, in a Fourier sense,
("far smaller" is usually sufficiently so if the different is 10x
different), then you *can* use lumped equivalents (aka resistors,
capacitors and inductors, et al) to describe the circuit with
"sufficient" accuracy. Otherwise, all bets are off.
As with any approximation, you lose something in order to gain the
expedience of simplicity that linear circuit theory gives you.
Physics and the real world came first, and man only creates an
approximation to emulate what his limited, feeble brain can imagine.
He calls that feeble vision of reality inductors, resistors and
capacitors, and linear circuit theory, in general. Nothing in the
real world is actually lumped or linear.
Thus using a component model is inherently wrong in a absolute sense
(which is why throwing around the word "definitive" is so dangerous),
but being wrong is OK in engineering if you have not cross the line of
where "just wrong" becomes "too wrong". The trick is knowing where
that line is what usually differentiates a good engineer from a bad
engineer. People say engineering is black-and-white: it's not - it's
definitely grey and fuzzy.
Any model for high frequency effects based on discrete components can
*never* be "definitive" in any absolute sense - its "definitiveness"
will always be dependent on how acceptable the inevitable error due to
*not using Maxwell's equations themselves* will be to your particular
case. In other words: how "definitive" is decision of what is
"sufficiently" accurate. Nearly every application has a slightly
different definition what "sufficiently" means so I have no idea what
a "definitive resistor model" really means without have a very
particular specification of accuracy criteria.
For instance, the claim of using "Puff component models up to 50 GHz"
is highly dubious if you are plugging them into SPICE or are ignoring
the implicit and inherent component/circuit size restrictions in that
component model. Things like distributed effects (component values
varying with jw or with physical dimensions like skin effect) are
exactly the parts of simulation that component models fail at first
and badly.
MM
