Wanted: Grooved Guides for Modules or Cards in customisable rackmount nest
Jim Gregory
----- Original Message -----
Newsgroups: sci.electronics.components
Sent: Tuesday, August 16, 2005 10:30 PM
Subject: Module or card Grooved Slides for customisable rackmount nest
enclosure
Looking for more of these - rather difficult to describe in brief - make
unknown, maybe Vero.
These sturdy, moulded guide ribs are made from black nylon/PTFE, fully
grooved 2mm wide & deep, with an optional, embedded, square 4BA or M4 nut
at front - for securing a threaded puller. The groove funnels out and
recedes at its front.
Beyond each end of the "rib body" is a 2.5mm slit stud in a well, behind the
groove, to
locate and engage, where needed, in the perforations of steel inserts
trapped in the
front and rear (different) extruded ali profiles across the nest, this pair
is set 188mm apart.
The grooves accept the raised longitudinal "fins" of modules that glide
in - two fins above,
two fins below - or the same grooved "guides" can be used just for keeping
full-height cards in place.
Length of each runner/guide 252mm
Width along 188mm body nearly 6mm, width over ali extrusions 9mm
Height 9mm
Distance between locating studs 213mm
Does anybody know where can I get another 24 of these, please? Thanx in
advance.
Jim
