Walky Talky (no internet required!)
i think i've ironed out all the kinks now (it was lagging when broadcasting) so until now i was hesitant to share it...
how it works... it uses your modem/router and broadcasts your voice over udp to any other device running the app, i've had it running ok on 3 androids all in different rooms (but too close and they echo unless you adjust the volume down)
https://play.google.com/store/apps/details?id=com.walkytalky.craigs.walkytalky
i've also run out of ideas for it lol... anyone? :)
how'd you mean? groups over local area network? because this does not have a server or ip like voip has, it uses multicast over udp...
channels (eg channel 1 to 255) and only if you listen on these channels will you hear it?
or have i misunderstood?
The site mentioned mentions "business groups". It means only those in that group can communicate with each other.
As I understand, you don't need a "server" or a "centralised control" to establish links - you only need a data connectivity.
On the face of it, it seems to be a viable alternate to provide voice communication on a "point to point" basis. Internet, no doubt, will enlarge the area of contacts, but this can establish voice links on a LAN / WAN.
Good idea, needs "publicity".
... "groups over local area network?".... Yes.
All the best.:cool:
no hardware required...
what it does is discover your wifi ip address, eg 1.2.3.4 then replaces .4 for a subnet broadcast 1.2.3.255
when a packet is sent like that, your modem/router will redeliver the packet to all connected devices on the network, i simply decode and play it back from any android running the app...
