Hello!
I'm hoping to find some insight for solving an issue with my old, old, old WACOM Cintiq 21UX.
Yesterday, my heart sank as this trusty piece of hardware, after more than 10 years of excessive, daily use (Impressive to be honest) could provide me with no more than a black screen. The morning, it worked BUT, I did take notice in how it started out quite dark, as if it had been in sleep mode and needed a moment (this has happened before, if the UI was slow to boot, following an update or so), thus I didn't think too much of it.
This forum is no the stranger to this "beast", which is how I found this place, from earlier posts dating back to 2010 asking for repair advice.
I can afford a brand new... but only just barely, like, I'll be dining on wooden shavings from old furnitures for a while, if I replace.
INFO:
However, the issue is that the LCD screen remains black. I'm sure I can confirm it's the screen, as it would normally function even without a computer attached, but give a little message in a box that it was receiving no signal and would enter Sleep Mode. Even this box no longer appears, which I'm guessing would indicate that the LCD screen is no longer receiving a signal.
I'm providing some pictures, but I really must apologize for the quality, as the loss of this hardware has nearly set me back to the Stone Age.
For better and clearer ones (with component info added), I can direct your attention to the 7 and 5 year old posts:
I can solder, but don't have much experience when looking for faults on something like this, so I would like to know and get an idea of where to start. Ideally, it's just a small transistor that has seen the end of its lifetime, which just needs to be replaced.
(here's to hoping)
Thank you for your time!
First image is the layout with the two suspects marked.
Second image is the primary board in the center where everything comes together.
Third image is the LCD circuit. This would get cozily warm! (but never burning)
INFO:
- The device Powers On. (Automatically switches on from standby when the Computer attached, is on).
- Assuming the pen functions and buttons are working as well.
- The Backlighting functions and triggers as it has always done (going on/off accordingly to the state of the device)
- Nothing smells or looks burnt (just... 10 year old well-used circuit boards receiving a daily dose of electric warmth)
- Need help with a Wacom Cintiq 21UX monitor (Reverse polarity applied) - SOLVED
- Schematic Wacom Cintiq 21ux
(here's to hoping)
