Adrian Jansen
Ross said::
:Joe G (Home) wrote:
:> Hi All,
:> I am look for some to purchase the magic volume pot cleaning spray.
:> What do you recommend?
:> and Where to get in Melb?
:> Thanks in advance.
:> Joe
:If its an audio control, and its 'crackly' that is a sign that its
:getting DC current through it. So its well worth checking any
:capacitors around the pot, and ensure they are not leaking DC current.
:Old electros are well known to do this. And after you replace the
:electros, you may still have to replace the pot to get rid of the noise.
Adrian, I note the "design engineer" tag on your post but you don't seem to be
aware of why pots get "crackly". Inside a potentiometer there is a wiper which
makes contact with the resistive element and every time you move the wiper it
attempts to dislodge some of the resistive material. The more oftern the wiper
is moved the more material gets dislodged. It is these dislodged particles of
resistive material which cause the noise in 99% of cases. It is NOT necessarily
(in fact, rarely ever) because they have DC flowing through them.
High quality pots such as Alps etc are costly because they made to resist (no
pun intended) the dislodging of material. That's one reason they are expensive.
I know how a pot is made, thanks. But in servicing many dozens of audio
mixer desks and similar gear, I had much experience with pots and their
problems. In almost all cases I ever found, 'crackly' noise could be
traced to DC current through the pot - not much current - even a few uA
is enough to cause problems. Of course there are plenty of other
failure modes too, but this one stands out as being very common. I must
admit I dont know exactly what causes the 'crackles', and its true that
removing the DC will stop it recurring, but I mostly found that I had to
replace the pot too. Certainly modern pots are better than the old
carbon track ones, but until the OP says what his pot actually is, and
even whether this is the problem, then we are all guessing.
Regards,
Adrian Jansen adrianjansen at internode dot on dot net
Design Engineer J & K Micro Systems
Microcomputer solutions for industrial control
Note reply address is invalid, convert address above to machine form.
