Volume pot 2 problems really stiff shaft and it worn away
This a pot of a sony str-de-935 amp part # 225-771-11 950m it was stuck on high volume and just spinning so i take it apart and in side it has a stupped light so its not 1 peace so the nob Shaft rotates on the plastic light and had a notch that conects it that had worn away can i solder it or glue it ? and lube the inside shaft as there is quite the resetence to spin it
I, for one, didn't get even an inkling of what was just said above.
Is it just me or is the Queen's English a thing of bygone days?
Welcome to EP!
If I understand you correctly it sounds like the pot is beyond repair. Time to replace it.
