Hi, I'm busy experimenting with insect zappers and need some advice.
I'm currently using a circuit I found inside a commercial bug zapper product, the product unfortunately malfunctions as soon as you let it run for long periods of time (it's meant to be switched on only for a few seconds, then switch it of if you've zapped the bug). The circuit contains a 4kV capacitor, some transistors and I'll need to go check again to remember the other components - effectively it converts 3V DC (2xAA battery) to 4000V and when something touches two wires simultaneously, the capacitor discharges and fries the insect.
I'm looking for something that's prebuilt that can convert DC from a transformer (can be anything from 1.5V to 12V) to a 4kV - 8kV (I'm guessing it needs to be AC to effectively deliver a lethal shock to a an insect?) range which I can fed straight through a grid of wires which can then be used to zap insects instead of having to build a whole circuit for it.
