CDRIVE
I only need a constant 9 volts out to get it where I need it but cant find a DC source that works. I can touch the heat sink about 3 seconds before I have to let go
A few things to mention.. First off the 9V battery is the weakling of the carbon battery family. Never rely on them for anything that needs juice. Secondly, A DC input should work on this regulator but the DC voltage should be 24 x 1.413. This is because the 24VAC spec on that page is an RMS value. It translates to 33.91V Peak. It's the peak value that you would need if the input is DC. So the DC input should be 33.9VDC.
Now comes the worse news. Since you only want 9VDC out this reg is a bad choice unless we can modify it. This is because you really only need a 12V overhead to feed a 9V regulator. Any more than that will waste power in heat dissipated by the regulator.
Now here comes a really dumb question. If you only needed 9VDC then why feed 2 series 9V batteries into a regulator? Though the 9V bat is a weakling it would have performed better connected directly to your load. In fact two fresh 9V batteries in parallel would have been preferable than two in series powering the regulator.
Chris
