Hi, new here and ignorant on matters electrical but have seen some interesting threads and you seem to be a helpful bunch, so here goes..
I am UK based and purchased a vintage 1970's Japanese audio amplifier which requires 100v as opposed to the circa 230-240v from my mains supply.
I purchased a UMI 1000w step down transformer 220v - 100v (allegedly for UK travel from Japan). It has a display of the voltage output which consistently shows 110-112v output when plugged into my domestic sockets. I assume the higher output is because of the source input being higher than 220v, ie 230-240v?
My question is, rather than purchase another transformer which would be expensive given the wattage I require, is there a simple, safe and reliable way to effectively reduce the mains voltage by eg sharing the load or using a long extension cable that would enable my step down transformer to bring the voltage down by 5-10v to close to 100v?
