I am working on a project that I want to use a battery pack that is 7,4v 1800mah to power a board for a ecig project that has the below specs what would you suggest to lower the voltage to a safe level to run the board.Basically I gutted a Handheld radio and building a ecig out of it but wanted to use the existing battery so this would be rechargable and have same look and feel as if it was still a real radio.....
EVOL DNA 30 Board Specs
Output Power min7 Watts max30 Watts
Output Voltage min 4 Volts max 8.3 Volts
Output Current 10 Amps
Input Voltage min 3.2 Volts typical 3.7 Volts max 4.3 Volts
Input Current min 1.5 Amps typical 6.0 Amps max12 Amps
Board http://www.evolvapor.com/datasheet/dna30.pdf
Battery http://www.amazon.com/Original-BaoF...id=1419951407&sr=8-2&keywords=baofeng+battery
