***MANUAL QUOTE***
.. Gain switching the feedback dividers eliminates effects
.. __ from the CMOS switch's series resistance.
.. .--|-_/ R1 | |
.. | | R3 | non-inverting gain
.. '---o-->o----+ | R5
.. o--- | ---+ |
.. o--- | -- | ---+
.. R2 R4 R6
.. GND --+----+----'
And if Gmin = 2, i.e., R1 => R2, etc., then a +/-5V switch
can be used with +/-10V output signals.
Thanks,
- Win
***END QUOTE***
Hi, if you recall from an old thread I had to design a voltage gain
switch using solid state parts. I finally made the circuit, and chose
the above configuration for the switch which is a 4051BP(stage 2). The
first stage is through a discrete in-amp(3 op-amp config, 10k
resistors, 200ohm gain select resistor) with a gain of 100. Stage 2 has
gains of 1, 5, 100 and 500, and Stage 3 is a follower. All Op-Amps are
OP-07.
Before assembly I first tested the ckt in a protoboard with DC as input
signal. It worked fine. When I finished the PCB I tested it and the
output won`t swing past +-6V. The DC power supply is +-12V (OP-07s),
and the 4051BP is powered with 5V1 zenners from positive and negative
supply respectibly. Supply power to ICs is checked. Output at Stage 2
Input is aprox. +-10V. Output without 4051BP and manual feedback (ie
short the pins) is +-10V. Always DC input signal. I measured with a DVM
the drop across the switch when any gain is selected and it equals the
output voltage (+-6V). When the output doesn`t saturate the circuit
works fine.
I don`t know what's the deal with this, I`m sure I did it on protoboard
and it worked fine. Tomorrow I`m gonna assemble it again and see what
happens, but I`m posting here because I assume the problem is something
else. I`m not sure why the output saturates at 6V, if anything I would
expect 5V.
Thanks in advance.
.. .--|-_/ R1 | |
.. o--- | ---+ |
.. o--- | -- | ---+
.. R2 R4 R6
Thanks,
- Win
***END QUOTE***
OP-07.
works fine.
expect 5V.
Thanks in advance.
