Hello everybody, I have constructed a small DC power supply with a variable resistor (10K pot) and the LM317. The circuit supplies the correct upper limit load ( ~16V from 18V supply) however, the lower limit only reaches about 7V when the pot is turned all the way up. The other problem I am having is with the output under a load. I hooked up an LED to test the circuit output, but quickly realized the voltage is plummeting to ~1 volt after the LED did not light up. I'm beginning to wonder if I have the potentiometer hooked up incorrectly, and if whether or not that could cause a voltage drop under a load. I used several resistors of various sizes to test to output voltage and my DMM read a voltage output you might expect given the resistance. I'm at a loss here. This is the first circuit I've ever really soldered together and its been heck of a learning experience. I have attached a simple schematic and a couple pictures of the project. If you could offer any advice, I would greatly appreciate it.
Note: I have a resistor connection drawn over top of the lm317 and not connected to a 4th port. Poor planning on my part when drawing out the schematic. I thought it would be helpful to label the PCB layout.
