hi!!!
I build my projects as units in separate pcbs and then link them up with wire bridges... well as things grow more complicated I have a problem in powering all the units that need different voltages with the same power source "a battery or an adapter"
I asked a friend he said you can use voltage divider but the problem is I couldnt do it without dropping the amperage to a very low level that the units couldnt work. so he said that there is an ic that can do that for me if I power it with proper voltage it distributes the voltage at different pins.
so please help me is there an ic that if i power it with 12 v for example and 500mA there will be different voltages at the pins??
thanks for you help
thanks for you help
