VFD causing noise
Hi
I got a small test rig that i built which is basically a phase converter (single to three phase) which i can use to supply a varying voltage and frequency to various devices... it consists of a three pole motor which is run by a VFD and a three phase alternator... you get idea o_O....
My problem is with the dc ammeter which has a shunt resistor connected in series with the alternator field coil to measure field current... it runs fine just until the VFD is switched on, when the VFD is switched on, the display that shows the current starts flickering as if the power where being removed and reconnected, As mentioned it runs fine until the VFD comes on, Disconnecting the 2 wires coming from the shunt resistor gets the ammeter back to normal operation but without any current measurement (only voltage). i'm sure this is a noise issue caused by the VFD, isolating the wires from the VFD wires didn't help much, they are all in one panel so i can't get them any further apart then this, lowering the carrier frequency on the VFD did show to be useful but not enough, it still flickers but not as fast as before. Using my oscilloscope i can clearly see noise on the shunt resistor wires that is going to the meter. Any ideas how to solve this problem ???
the link below show the ammeter i am using with the shunt
https://www.aliexpress.com/item/DC-50A-Digital-LCD-Power-Meter-Monitor-Power-Energy-Voltmeter-Ammeter-12V-24V/32697593944.html
What VFD and what is the nature of the motor? 3 pole motor?
What kind of regulator on the alternator field?
M.
Vfd is a Mitsubishi D740 1.5k motor is 3 phase and the field is controlled via a PWM supply that is manually adjusted
The ammeter cannot directly read a PWM'ed current correctly. IMO you need to RC filter the voltage developed across the shunt and apply the filtered signal to the ammeter.
