VERILOG and VHDL
could someone pls tell me books which i could follow to implement
projects on FPGA or CPLD using XILINX or ALTERA.How much does an altera
or xilinx complete kit cost in INDIA.
PeteS
My favourite book that covers both Verilog and VHDL is 'HDL Chip
Design' by Douglas J. Smith.
You'll have to contact the Xilinx or Altera people for the cost of a
dev kit where you are.
The design flows in the Altera and Xilinx tools are somewhat different,
but independent of the HDL language used. You can get the development
environment (mostly) free on the web from both vendors.
Cheers
PeteS
Slurp
You do not need to know Verilog or VHDL or indeed any other textual HDL to
implement designs in FPGA's or CPLD's.
Personally I find they get in the way of producing high speed complex bug
free designs.
I design highly complex image processing/camera/video systems using nothing
more than schematic capture and a hierarchical design structure.
This provides designs that are highly modular, self documenting and easily
understood and modified years later by other engineers.
Slurp
Nico Coesel
free designs.
Depends on what you are designing. Complex logic is terrible to
maintain when contained in a schematic. The same goes for showing the
design hierarchical overview in HDL. My designs are mostly hybrid.
Schematics to connect the blocks and do simple counter / buffer stuff,
HDL for complex statemachines. And some documentation ofcourse.
Cheers
PeteS
K
krw
free designs.
Nonsense. VHDL and Verilog are used industry wide for such things.
Apparently it's only you who has this problem.
....and you can't do this in a HDL? At one time I thought like you,
but then I grew up. Schematics might be great for dataflow and
analog circuits, but they suck for any complex logic.
Nonsense again. VHDL is quite easy to make self-documenting. My
guess is that you've never really tried to change tools. I have,
and I'll not go back, willingly.
Slurp
Nowhere did I say VHDL and Verilog is not the norm - just that it really is
not necessary if you know what you are doing and want to get the job done.
I don't consider I have a problem at all, I can get to a solution before
anyone else using a HDL.
Didn't say I couldn't ( you seem to be very defensive!) . I can write
Verilog - does not get to the solution very quick, easy to intoduce bugs and
very hard to find your way round hundreds of pages of script.
A picture is worth a thousand words. If you create or use megafunctions you
really do not need to be involved with gate level logic - I guess graphical
languages have moved on since you last looked!
Horses for courses - you carry on your way and I will carry on mine - I
certainly don't have a problem with that.
Slurp
K
krw
You must do some pretty simple stuff. Try designing a processor
using only schematics. It was done thirty years ago. It is no
longer. I wonder why?
Defensive, nope. I'm on the offense. Defense is for wussies. ;-)
I can write
You must be very poor at it.
Nope. A well done hierarchical design in a HDL is quite easy to
read. Complex state machines are a piece of cake.
I think you're shortchanging yourself. Like I said, I once
resisted VHDL (and even had another engineer do the designs from my
specs). No longer.
Slurp
One module (out of around 68) of a recent Altera Stratix II design was a 32
bit RISC processor designed from scratch and verified in less than 2 weeks.
The compiler took another 2 weeks to write.
All designed using hierarchical schematics. The whole project has taken me
single handed less than 6 months.
If that is simple stuff then I take my hat off to you.
On the contrary.
...... as are they using a graphical approach.
Experiance and results say not.
PeteS
On the contrary.
I expected a Holy War [tm], but not necessarily over the schematic/HDL
issue ;)
FWIW, when I do FPGAs, I do them exclusively in HDL. I personally find
it much simpler to deal with than a schematic, although I am perfectly
at home in schematics (I had better be ;)
I had quite a learning curve to get to this, but once I got comfortable
with HDL [some years ago now] , I personally won't look back - a
description of a part in Verilog or VHDL tells me more (imo) about the
part than any pure schematic symbol ever could. Interestingly, one of
the reasons I started learning HDL was because I had to write some
programs to implement a bunch of boundary scan tests, and BSDL is a
subset of VHDL. I chose to learn BSDL as it is integral to really
understanding JTAG tests.
There are those who see it differently, of course.
Cheers
PeteS
John Larkin
free designs.
Slurp
I agree, but we are in the minority. I find that my schematic-based
designs are simpler, faster, and far less prone to bugs as compared to
things that HDL designers do. HDLs are good for some things like
tables and address decoders, just wrapped in a box and properly
commented.
I greatly prefer flipping through, say, 30 pages of nicely commented
schematics as compared to, say, 5000 lines of cryptic, uncommented
VHDL.
All my FPGA schematics begin with a block diagram, a table of
contents, and timing diagrams.
John
Slurp
commented.
VHDL.
John
Eureka! - A like minded professional at last!
As you say John, we are very much in the minority!
May be it is just the way our brains are wired.
Slurp
Joel Kolstad
True.
free designs.
OK; hopefully you realize this is not true for everyone.
nothing more than schematic capture and a hierarchical design structure.
All the contemporary Verilog/VHDL "suites" (e.g., ActiveHDL, ModelSim, etc.)
support a mixed schematic entry/VHDL/Verilog design style. IMO, that is the
best of both worlds... use an HDL for fancy behavioral logic like state
machines, use schematics to visually "tie together" the various levels of
the hierarchy... and then use whichever you prefer for the
complex/high-speed parts.
---Joel
martin griffith
commented.
VHDL.
John
Can you recommend an idiot level (me) schematic/fpga system, as I want
to convert some ttl/cmos circuits to a single lump, memory address
counters and glue logic etc.
I've looked at the Xlinx site, and I couldnt even figure out what
breed I wanted. I'm downloading one of their demos at the moment
martin
Slurp
martin
If you download the Altera Quartus web edition from www.altera.com (you need
to obtain a free license file) - one of the included libraries actually
holds 74 series functions, eg in the schematic editor if you double click on
the schematic page, enter "7490" or whatever - up pops the appropriate
symbol and underlying logic. For more sophisticated counters (up to 256
bits) enter "LPM_COUNTER" and you are presented with an easy to use
multipage wizard to set up your counter configuration, and an appropriate
symbol is dropped on the schematic when you finalize the wizard.
HTH
Slurp
martin griffith
HTH
Slurp
Wow, thanks for that, brilliant [insert ASCII for thumbs up here]
martin
Slurp
need to obtain a free license file) - one of the included libraries
actually holds 74 series functions, eg in the schematic editor if you
double click on the schematic page, enter "7490" or whatever - up pops the
appropriate symbol and underlying logic. For more sophisticated counters
(up to 256 bits) enter "LPM_COUNTER" and you are presented with an easy to
use multipage wizard to set up your counter configuration, and an
appropriate symbol is dropped on the schematic when you finalize the
wizard.
HTH
Slurp
...... forgot to add that for your application I recommend you look at the
Altera MAX II range of CPLD's. A CPLD has on board non -volatile
configuration memory which means the programmed device is 'stand alone' .
If you use an FPGA you will need external NV memory - normally Flash, and
some kind of boot loader. Altera do produce chips which have both the Flash
and boot loader integrated in one device but these work out much more
expensive than a 'roll your own' CPLD based loader and separate Flash.
Another plus is that the CPLD's are much cheaper than an FPGA - a smallish
MAX II part of the order £2 - £3 will typically hold the equivalent of
50 - 75 MSI 74series logic functions with ease.
Slurp
John Larkin
HTH
Slurp
The Xilinx schematic library also has a lot of 74xx TTL blocks, plus a
lot of general-purpose latches and counters and gates and stuff.
You can grossly waste resources here, like using three outputs of a
1:16 decoder, or five bits of an 8-bit latch; the compiler will strip
out the stuff that's not actively used.
John
John Larkin
Of course. Not everybody can produce high-speed, complex, bug-free
designs.
John
