Hi there. This question may be pretty basic but I don't know much about variacs.
Here is the scenario:
I plug in the variac and set it to 0V. I have a voltmeter across the output and also the test probe of my oscilloscope to one of the outputs leads.(I disconnected the ground from the scope test lead so as to not create a short). On the meter I see 0 Volts. On the oscilloscope I see a full 118V sine wave. When I crank up the variac to 120 volts I get 118 volts on the meter and a flat 0volts on the scope. Can someone explain this? I am getting conflicting readings.
Thanks for the help.
