I hope someone may be able to offer some insight into this, i have been playing with a circuit derived from LM317 datasheets for a variable power supply.
The constructed circuit has a digital volt meter which is powered from a separate source; with no load the supply can be swept through a range of 0v to 35.9v. However, when a load is attached the voltage drops down to virtually nothing, a small 12v bulb will only glow dimly even on maximum output (reading of 4v on the meter), an LED lights up but doesn't burn out when you increase voltage to maximum (reading of 3v on meter).
I'm confused by this, i originally drew the circuit in multisim for reference before i started construction, running a simulation yields the same results, the virtual circuit behaves exactly the same way as the real one with a pitiful output.
I have tested the components and found no faults, replaced the original lm317t with a lm317k, also replaced the linear pot. I still can't see the problem. I only wanted a small variable PSU for testing other circuits up to 24v!
I am attaching the drawing for what it's worth, it is quite a basic and common design
Thanks in advance.......... TW
