Winfield said:
One interesting idea to consider is using DC currents in
the winding to magnetically saturate the core, reducing
its permeability. This method can easily exceed 4:1
ratios, but it's best done inside a servo loop where
stability doesn't matter.
What kind of stability do you need?
I was reading this thread, and was just about to suggest saturating the
core with a second winding. This way you can control the inductance
electronicly.
Recently I have been playing around with something kind of like this.
I have been characterizing inductors to find out where and how they
saturate, by putting a DC current in one winding and measuring the
inductance on a second winding. The complication is the impedance of
the DC current source appears on the measurement winding. To get a
decent measurement I have to make sure the DC source impedance is very
high relative to the indutance I am trying to measure.
The inductance of the parts I am looking at varies from about 1.5mH to
less than 50uH at 100kHz. (About 30-1 inductance change)
There are some tricks to make the DC source impedance less of an issue.
These are old magnetic amplifier techniques. You can use matched
inductors in series with the DC windings coupled in opposite directions
so the coupling cancels out. Something else I have been meaning to try
is to put two windings on a flat core on quadrature axis so they don't
couple. This is kind of like the variometer with the inner winding
turned to 90 deg.
I would also suggest a core with a lumpy shape rather than a torroid.
An E core or something. If the core saturates unevenly the inductance
will roll off more gradually and be easier to control.
This is all probably more complicated to impelment then what you are
looking for, but hopefully is still interesting.
Ethan
