N_Cook
Anyone know?
No underlying idents , only 3 years old at most
From pcb Enumber, the boards are made in Hong Kong, despite Union flag
logo
on the overlay and "Made in England" on the chassis. I will assume No-Name
Chinese valves unless anyone knows any better
Gareth Magennis said:I've been buying and fitting JJ Tesla valves exclusively for the last 5
years or so. I bought a whole bunch straight from the factory (EL34, EL84,
6L6, ECC83 - not tried any JJ6550's, usually get Svetlanas as required).
I can't remember seeing any amps come back with a failed JJ Tube I fitted.
When I do see an amp back I recheck the bias current and they are always
still closely matched.
They are priced well towards the cheaper end of the quality tube market.
(Last Orange amp I had, a Rockverb 50, I replaced 4 x 6V6 with JJ's, haven't
seen it since)
Gareth.
"Nutcase Kook"
** Orange Amps do not use or recommend any particular brand of valve.
But you would be a fool to use anything less that the best EL84s and
EL34s you can get - cos those amps are sooooooo tough on output
valves.
Svetlana and JJ are the ones to look at with EH down the list somewhat.
..... Phil
PAIR-/310210519111?Sorry, that post reads a little curt, but for example:
http://cgi.ebay.co.uk/EL34-CV1741-MULLARD-NOS-MATCHED-
While at it with Orange amps. Nasty metallic buzz like mains powered shaver/
engraver/ poodle clippers. Varying level of noise with amount of load.
Mains Tx central bar of an outer "E" lamination loose. Simple enough to deal
with once you know the cause. Remove the matching "I" to drible lacquer both
sides. The wiring bobbin is loose within the iron laminations block, so
plenty of space to allow a lamination to break away. Will also push some
silicone rubber sheet in there to avoid re-occurance hopefully.
You could experiment to see if any of them could really tell the
difference in a properly controlled double blind test.
I am highly suspicious of any opinions regarding "sound quality"
obtained otherwise.
Gareth.
