V/I for panels
David Lesher
How much does the cell size vary over model/technology? I ask because I am seeking
panels with more cells in series, to get higher voltages.
Josepi
None.
Shop for price and physical stability in construction, ease of mounting. and
voltage needed.
Thicker lines between the cells means less overall efficienciy due to less
PV area.
seeking
David Lesher
stevey said:
Curious why you ask this question.
Working on a system with lots of line between the panels and the
inverters. Hence lots of loss, and lots of {cable} $$$.
So {say} 20KW @ 250V [i.e. 80A] will have more loss than 20KW of
panels at 550V. [36A]
Obviously the # of cells in series in an array determines the
output voltage. But how much do different panel designs, and
different technologies, vary the available currect?
Mauried
A host is a host from coast to [email protected]
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Have a look at thin film amorphous panels like Kanekas.
Panel voltage is around 70V.
Insulation voltage is 1000V so you could wire them in series to get
500V+, or even 1000V .
Why dont you simply relocate the inverters to where the solar panels
are, rather than run long lengths of DC .
David Lesher
[email protected] (Mauried) writes:
Thanks; will do.
Panel voltage is around 70V. Insulation voltage is 1000V so
you could wire them in series to get 500V+, or even 1000V .
Costs of stepup xfmr to 4160, MV cable to house and stepdown again.
Josepi
Panels range from a few watts to the typically largest 235 watts for
residential usage.
The voltage is 12, 24 or 48 volt base (Usually about 150%) and you just put
more in series to get the system voltage you want. As long as the impedance
(same silicon style and capacity) match that works fine. Different banks can
be put in parallel to get current capacity up as they are considered
constant current devices and will not "fight" each other...generally through
fused branch circuits to avoid fires if a short occured
Many run high voltage systems and the inversion is a simpler and cheaper
circuit as no large transformation is required, providing you are not
running a battery energy storage system, at that high voltage, too.
The line losses become insignificant and most with any size of power run 48
volt systems, with batteries, or higher without, partly due to eliminating
the losses. The 120KW system across the street runs co-gen inverters under
the panels on the rooftop and are all adressed by a communications bus that
displays and controls the individual co-gen circuit banks connected to the
grid. I am not sure how they are gang connected...probably a multiply fused
splitter / switch / isolation box.
