Arlet Ottens
Paul said:Your solution seems to be ideal. For my application, I cannot use a soft
start, because I must apply a full current waveform to a circuit breaker to
simulate a fault, and measure its response time accurately. The best I can
do is time the initial application of the test voltage to coincide
approximately to the expected zero crossing of current, based on the
impedance of the source and the load, which are both mostly inductive.
Also, in my case, the load itself opens while the test set has voltage
applied, and it may open at any point on the waveform. Thus arcing and
inductive spikes are inevitable, and the transformer may have some remanant
magnetism after the breaker trips, which will then cause a high inrush on
the next test.
But I have considered adding a demagnetizing sequence after the trip is
detected. I think a series of phase modulated pulses with gradually reduced
duty cycle might reduce the magnetization of the transformer to a minimal
level for the next test.
I tried some experiments using phase control on the SSR to slowly turn
off the transformer over 50 cycles (1 second), followed by a test using
a few whole cycles starting at a zero crossing.
I noticed there was still some increased current surge (2 times normal
on the first half cycle), depending on the polarity of the first half
cycle of power. Apparently, the demagnetizing wasn't complete. However,
it is a lot better than starting with the core fully magnetized in a
unfavorable direction. Results may vary with transformer type.
You may also be able to put the core in a consistent magnetized state
after a test, and always start at opposite phase.
