Steve Harvey
I am working on a re-design where the current product is based on a
8-layer 1oz PCB and is being re-configured to a 6-layer PCB to save
cost. In some areas of the design, it is desirable to minimise the
resistance of certain current-carrying tracks which are currently
paralleled on all 8 layers. The change down to six layers will inrease
the effective resistance in these critical areas and I am consdering
the use of "solder coating" on the "solder-side" to effectively
increase the conductivity in this area (which is wave soldered) to
compensate.
I have no direct design experience of doing this but have seen
examples in other products (power supplies and automotive ECU modules)
and would appreciate any advice as to the benefits and pitfalls. I am
sure that this process has a well know "name" but not knowing what
this term is, I would find the WWW of little help or guidance.
I am working on the assumption that all I need to do is to edit the
solder resist away in the areas that I need filled and the soldering
process does the rest but I am sure there are some dos and don'ts that
I need to know first.
Of course the resistivity of tin/lead is significantly higher than
copper, so the coating will need to be signicivantly thicker than the
copper traces to compensate for the missing internal layers.
Thanks in advance
Steve Harvey
steveharvey [at] dsl [dot] pipex [dot] com
compensate.
Thanks in advance
Steve Harvey
