John Larkin said:
The horizontal deflection transistors are vanishing, too. Beautiful
1400 volt things. Their c-b diodes made wonderful drift step-recovery
diodes, some nice doping coincidence. Apply 48 volts in the forward
direction, wait a while until you get 50 amps or so, then reverse them
hard. SNAP!
My experience (limited, since MOSFETs are just that much nicer!) is that, at
least without a huge amount of reverse bias, they tend to break down at
Vceo, which is a paltry 600V, versus the 1500V Vcbo. This is kind of
unusual as BJTs go, because I made that measurement at Vbe = 0 (inductive,
pulsed), a condition where the average BJT goes pretty close to Vcbo.
(2N3904 goes to 80V or so with a moderate B-E resistor, and also exhibits
avalanche behavior which can be of use.)
I'm surprised they snap well, I'd think the capacitance and lead inductance
would hamper things greatly.
That 1kV pulser you made, you ended up with a very particular selection of
part number, manufacturer and reel, of some common rectifier (1N4007 or some
such), right? 50A through a HOT, if it snaps well enough (given its
capacitance), should do about as well. Hey, if you can push it to 1500V in
a split second, that's even more into 50 ohms than the 1kV you had!
Tim
