hi all, im new here and i have a question which im not too sure about.
im trying to build a simple circuit with a couple of old laptop battery cells,which are roughly 2.8v each, im putting them in parallel to achieve most amperes because im going to be using it on my model airplane and the glow plug needs quite alot of amps, anyway i used 6 rechargeable 1.2v batteries and they work fine but i want to use the laptop cells so that i can se the others batteries in camera or so, but my question is this, ive put a potentiometer in the circuit and it drops volts to what is required, 1.2 -1.5 volts for glowplug, but then the amperes isnt enough, so sdoes the pot throw away the amps also? or how would i go about building the setup without losing amps but still be able to bring down voltage ?
any help would be appreciated
