V
Vivek B
Hi folks,
My code is handling both timer0 interrupt and SPI interrupt. And I
don't want to loose any of the SPI interrupts and hence thought of
making the timer0 ISR to work in NOBLOCK mode. But when i use
ISR(TIMER0_COMP_vect, ISR_NOBLOCK)
/* Code */
the compiler gives an error: "macro "ISR" passed 2 arguments, but
takes just 1"
where it works fine for
ISR(TIMER0_COMP_vect)
/* Code */
Right now I am implementing the code as follows
sei();
/* Code */
But I would like to use the first one. Isn't the first implementation
suppose to work??
Anyone has any guess why it is not working...
Thank you ..
Vivek.
/* Code */
takes just 1"
/* Code */
sei();
/* Code */
suppose to work??
Thank you ..
Vivek.
