Makhan
Hello all,
I have a very typical problem with a twist. Here goes:
I have a main loop running a piece of code. However, upon receiving
character '0' from serial port (or any 8bit code for that matter), I
want to read 8 or 16 or lets say n number of bytes from serial port.
So here is what I did, I created an updateFlag bit which gets set
whenver the true code is reached and the ISR quits. Whenever in the
main loop I reach the place for checking updateFlag, I deactivate the
ISR for Serial Port and assuming that now the serial port will act
just as normal, I run a debug code of reading a byte and outing it.
Only the serial port interrupt flag remains inactive while I am in
that function.
So the ISR goes like:
ISR_SP:
JBC TI, QUITY ; if TI caused it, just quit
MOV A, SBUF ; if '0' = 30 then update the IDATA
ADD A, #-30H ; else skip the update
JNZ QUITY
SETB UpdateFlag
QUITY:
RETI ; if TX irq just returns
and the main loop:
while (1)
if (UpdateFlag == 1)
/*---------------------------- Debug ------------------------*/
EA = 0;
choice = GetByte();
choice++;
OutByte(choice);
UpdateFlag = 0;
EA = 1;
// Some functions here
My problem is this that the ISR works fine if I dont involve serial
port reading writing, that ISR would turn on or off any port correctly
upon receiving character '0'.
Similarly the GetByte and OutByte routines work fine as well when
Serial port is not on interrupt.
Its only after combining both I end up in problems, can anyone see any
potential problem in the approach?
Thanks in advance
Makhan
that function.
ISR_SP:
JNZ QUITY
SETB UpdateFlag
QUITY:
and the main loop:
while (1)
EA = 0;
choice = GetByte();
choice++;
OutByte(choice);
UpdateFlag = 0;
EA = 1;
Thanks in advance
Makhan
