Using generic power adapter for Wi-Fi accesspoint
Jonas
Hi guys,
My Wi-Fi access point (D-Link DWL-700AP) ceased to work, but I found
out what the problem was. The power adapter is dead. However, in my
junkpile I managed to find a generic power adapter from some old
appliance, and it seems to work with the access point.
Now, I have a question: Is it safe to use the generic one? I am afraid
of burning down my house or something like that.
The original adapter for the access point (now dead) said:
Input: 100-240V, 50-60 Hz 0.5A
Output: 5V 2A
The "new" one (don't know where I got it from) reads:
Input: 230V ~ 50 Hz 140 mA
Output: 6V 2.1A
(We have 230V 50Hz here in Denmark where I live)
Thanks,
Kind Regards, Jonas
jakdedert
Jonas said:
Hi guys,
Output: 5V 2A
Output: 6V 2.1A
Thanks,
Kind Regards, Jonas
Probably going to work okay, but I'd be more comfortable if it was a 5
volt unit. That's a 20% overvoltage, but likely there is voltage
regulation within the router, and tolerances on power supplies is not
all that tight anyway.
jak
Arfa Daily
regulation within the router, and tolerances on power supplies is not all
that tight anyway.
jak
You could always open it up and place a 2 amp rated standard silicon diode
in series with the output. that will drop the output voltage by 0.6v or so
to a more 'comfortable' 5.4v
Arfa
G
Geoffrey S. Mendelson
It depends. Some things don't seem to care, 5 volts or 6 volts or even
8 or 9 (not recommended) work e.g. EdiMax and D-Link routers I have.
Other things will work with only 5 volts e.g. a Linksys PAP2 I have.
The Linksys simply will not turn on if the voltage is too high. :-(
Geoff.
Jonas
Hi guys
Thank you everyone. I'll consider try dopping the voltage as
described.
Thats interesting. Mine is a D-Link, and it seems to be doing fine so
far at 6V...
Regards, Jonas
W
whit3rd
Output: 5V  2A
Output: 6V  2.1A
As for safe-against-fire, it's probably OK. All the adapters have
similar fire-safety requirements... but your WiFi access point
might burn up tomorrow. Either reverse-engineer the DWL box,
or find a more suitable adapter. "5V" might mean 5V +/- 10%,
but it isn't a match for "6V". In a pinch, you could tap your
(presumably nearby) PC power supply, the red + black wires on the
dangling disk-drive connectors have plenty of power to spare.
So much, that you should only run wires outside the box after placing
a proper (3A) inline fuse.
