Exactly, fuel atomisation and fuel viscosity are different things.
The invention claims to reduce fuel viscosity, which *may* make a difference
to the economy in a limited number of cases, but the same effect can
probably be achieved in a number of other ways, some of which are probably
cheaper, and/or already being used.
MrT.
I presume it's easier to atomise a low viscosity fluid, so the two
things must be related. Just how much an effect a smaller droplet size
has on combustion efficiency would be debatable, though. I'm finding
it difficult to accept the researchers' claim that they reduced the
fuel consumption of a Mercedes-Benz diesel car (I wonder who supplied
it?) from 32mpg to 38mpg. Under city conditions they claim a fuel
saving of 12-15%, and on an engine dyno they claim that "the power
output was improved by about 20.4% at the same fuel consumption rate".
Assuming the results are genuine, this would suggest that combustion
in an unmodified engine is incomplete and that approximately 15% of
the fuel is normally burnt up in the exhaust. I find this hard, if not
impossible, to accept. Alternatively, it could be that better
atomisation results in a more efficient combustion flame. Perhaps an
adaptive ECU could back off the ignition advance if the flame were to
propagate faster (anti-knock), and maybe this is where the combustion
efficiencies come from ???
Or maybe it's just an elaborate scam.
BTW, I wonder how a car would fare with an injected engine against an
identical carburettored version? Presumably the former would have much
better fuel atomisation. Could one expect 10% or 20% lower fuel
consumption for the injected version? If not, then that would tend to
discredit the researchers' claims.
- Franc Zabkar
