The Doctor
Wonder why no one has thought of this before!
http://www.temple.edu/newsroom/2008_2009/09/stories/taofueldevice.htm
The Doctor said:Wonder why no one has thought of this before!
TT said:It has been done before and will be done again.
Here is a basic test to apply to any device like this that you see
advertised. "If a simple device like this could deliver even a 5% increase
in fuel economy don't you think GM, Ford, Toyota etc would snap it up and
put it on their vehicles?"
Or wouldn't you at least to expect to see it in F1 racing?
The said:Wonder why no one has thought of this before!
It has been done before and will be done again. It is all bullshit.
These guys spend Billions on more fuel
efficient vehicles and you really think some nut case in a back room can do
a better job?
Cheers TT
That was my first impression, and I'm still very skeptical, but the
researchers appear to have some independent test results that support
their claims, at least in respect of diesel engines.
The researchers claim that one Italian diesel engine manufacturer has
tested the device and obtained a 5% improvement on the dyno.
**In very cold conditions, decreasing the viscosity of Diesel makes sense..
It has been done before. These guys:
http://www.tycothermal.com/australia/english/specialty_heating/
Have some excellent products. Formerly Raychem.
Franc Zabkar said:This is a more technical article on rheology by the same researchers.
It is aimed at reducing the viscosity of crude oil for transportation
via pipelines:
mlReducing the Viscosity of Crude Oil by Pulsed Electric or Magnetic
Field"
http://pubs.acs.org/cgi-bin/sample.cgi/enfuem/2006/20/i05/html/ef060072x.ht
Franc Zabkar said:It couldn't even be tested without serious modification. The
researchers found that at 1900 RPM the optimum electric field was
1kV/mm, and the minimum time required for the fluid to be subjected to
the field was 5 seconds. The fuel flow under racing conditions would
be an order of magnitude greater, which would mean that the device
would need to be much longer. Of course you could have one small
device per cylinder ...
the_dawggie said:Well 'lux turbo diesel made it to North Pole.
I'll bet they used a fuel additive though!
(Commonly added to diesel in all extremely cold climates.)
TT said:Applying for a patent does not necessarily mean the thing works.
BTW Harley's are the most efficient engines at turning petrol into noise
without the side effect of horsepower ;-)
Mr.T said:Actually they say the effect lasts for a couple of hours, so could obviously
be done in the fueling rig before it even goes into the racing car. Therfore
no weight penalty, or other problems.
MrT.
