I have several RAB STL200LED motion sensors. Each is wired to 2 LED flood fixtures (20w each). Once the sensors trigger the lights, the lights never completely darken again. It appears that the sensors leak current.
Tech support at RAB says to install a relay. My question is, what kind of relay do I need, and how is it wired? Also, is it just me, or does it seem pretty lame to have an issue like this with a $95 motion sensor? Finally, I've heard that another solution would be to wire a low wattage nightlight into the circuit to draw off the excess current. Will that work reliably?
