QUICK VERSION
Using LED calculators like http://www.bowdenshobbycircuits.info/led.htm andfor a given supply voltage, why would I not use more LED’s and have a smaller current limiting resistor?
DETAILED VERSION
Why – Mainly… I just want to experiment with LED lighting. But secondarily… a 120VAC LED bulb is $25. With some $2 worth of electronics I can make a nice under cabinet light.
I’m not an EE. I don’t know what may be important information, so I’ve included everything I’ve done. I’ve basically started with this article http://www.bowdenshobbycircuits.info/page10.htm#ledlamp.gif
• I’m using a free-be Harbor Freight volt meter
• My AC voltage is 121.4 VAC and pretty steady.
• Using pieces out of an old, burned out PC power supply, I’ve made thebridge out of (4) IN5406 diodes
• My measured DC out of the bridge is 108.6 VDC
• I’ve paralleled a 104J (400V) capacitor across the DC output found inthe same power supply
• This brought it up to 161.2 VDC.
All this… “I think” I understand.
Now, this is what I’m having difficulty understanding. In the example (and everyone else’s) the number of LED’s is quite a bit smaller than could be supported by the voltage available. Thus the current limiting resistor is quite large in both ohms and power rating. In my limited understanding, I would think one would want to use more LED’s, thus reducing the amount of electricity wasted as heat in the resistor. As a secondary benefit,I’m finding it far easier to find 1/4 and 1/2 watt resistors instead of 2.5W resistors.
In my specific example, I used the “LED Series Resistance Calculator”. The LED’s I have are White LED’s ($3.60 for 100 from China) so I have plenty to try and/or burn up
They’re rated ~3.5V at 30 mA.
• If I use 25 LED's at 3.5V, 30mA, 161.2V, the calculator says I need a 2400 ohm, 2.263 Watts current limiting resistor.
• However, if I use 44 LED’s, it suggests I can use a 240 ohm, 0.216 watt resistor.
Thus, I would be putting out 75% more light for the same amount of electricity and using an easier to find quarter watt resistor. Is there some otheraspect about this circuit that suggests that is a bad idea?
Thanks for your help.
DETAILED VERSION
