Serious Machining
I would like to use a Radio Shack # 272-704 120 volt neon lamp as an
ON/OFF indicator on a 240 volt circuit (single phase, no neutral).
Based on the Ohm's Law calc's I've done, it appears I need to add 889K
ohms resist in the circuit for this 0.032 watt (0.00027 amp) lamp.
I'm considering using two Radio Shack # 271-1133 470K 1/2 watt
resistors in series, connecting one to each lead of the lamp assembly.
The 940K resistance (893K @ 5% tolerance) is more than the 889K per the
calculation, but this 120v lamp only needs a min of 70v to fire.
Is there any thing I'm missing in my thought process that someone in
this group may recognize as a "newbie's bonehead blunder" ?
Thanks for any forthcoming assurance or constructive advice !
- Dennis Anderson
- Dennis Anderson
