G
Grant
Stuff that, spent most of today learning Eagle
So what? I've not heard of them, therefore they have no track record
for this particular application, where the topology I'm using does have
a track record.
No, I really don't. So I didn't, now.
I like nice symmetrical swap the Rs and Cs to get the complimentary
function with S-K.
Grant.
Leapfrog design is well known. You can verify the filter with spice.
Regarding something that will work the first time, you have the wrong
philosophy. The design has to work every time. Leapfrog filters have
the lowest sensitivity to components of any filter design.
a track record.
The biggest source of error in an active filter is the caps, and you
want to add more caps than is needed?
Lowpass leapfrog design is pretty easy. You need to pick a prototype
LCR filter which ends in a cap shunting the load resistor. When you
draw the signal flow graph, this will become obvious.
function with S-K.
Grant.
