USB interface to microprocessor?
need to add a USB interface to an existing microprocessor to make it a
slave USB device, receiving byte code commands, and sending digitized
data arrays.
Is there an off-the-shelf module available for that? e.g. that would
convert USB to SPI or bidirectional parallel etc?
Spehro Pefhany
data arrays.
You can buy a USB <-> RS232 serial cable for cheap (like $10-$15 US
retail)
Best regards,
Spehro Pefhany
Jack// ani
If...I picked you fine....I'll be sending form the USART which will be
converted into USB....but what about the data speed??
I
Ian Stirling
Whatever you set up at the PC end.
