Y
Yannick
Maybe some remember i was developing a laser range finder for my
master thesis. Now 2 months from the end i can say it is a succes. I
can measure distances up to 10meters from white objects. The
resolution is good the first few meters (1-2cm) and afterwards worse
and worse (10-15cm for 10 meter). The problems lies on several things
, i still use a dds frequency generator with 125Mhz clock , for the
higher frequenties (20-30Mhz) the sinus is far from perfect. The
second problem is ofcourse the photodiode preamplifier wich is still
designed around the opa657 in the most simple configuration. The
thirth bottle neck is that i use a phase detector ic from analog
devices (AD8302) wich does clipping on the signal before multiplying.
Soo signals lower then noise cant be detected, this will be solved due
using a DSP processor (ad's blackfin) and with signal averaging i can
measure signals lower then noise (it will only take more time).
There is still something strange with the photodiode preamplifier , i
tried many things including the R-C-R trick described by winfield
hill, although simulation in microcap gave me stunning results and
huge bandwidth improvement, in practice it didnt work, i the best case
i had exact the same results and mostly worse. Then i thought of
something simpler, just using a resistor tree network to reduce
resistor values and still have the same total feedback resistor (68K
in my case). This is described in photodiode amplifiers from gerald
greame and i did it exactly like he pointed out. i use for R1 = 22K ,
R2=270 and R3 to mass = 100 soo i will have a total feedback
resistance of Rfeq=R1*(1+R2/R3) = 81.4K.
In simulation this worked wonderfull,more gain, more bandwidth then
with my singe 68K feedback resistance. But in practice the result was
worse. What can this be? everything is made in smd components with a
open ground plane to reduce capacitance to ground and everything is
shielded in a RFI case.
I want to thank Colin,Winfield hill and al the others for their help
in the beginning (6 months ago) of this project , it made everything a
lot easier for me.
greetings,
Yannick
lot easier for me.
greetings,
Yannick
