In the 90s Sega released the Genesis and two add ons, the Sega CD and the Sega 32x. All three of these add ons require their own AC adapter, which as you can imagine is a real pain. In their infinite wisdom Sega designed a way to power add ons from the base Genesis, but for some reason never utilized it. Its very easy and well documented on how to connect those contacts to allow the Genesis to power both add ons. One would then replace the stock 9V 1.2 Amp AC adapter with something that could output ~3 Amps to power this behemoth.
What I want to do is see how much current the actual systems require, and how much is being wasted by the 7805 regulators present in all three system. I'm thinking maybe I could replace it with something more efficient like the LM2676 (which I have several free samples of). But I want to make sure that 1.2 Amps is actually sufficient to power all three systems off of the stock power brick if I replace the regulators.
I tested the current in the Genesis last night. The original motherboard revision of the Genesis uses 2 7805s. I remove the voltage regulators to a breadboard and tested the current. Both regulators had a current of about 350mA running through them when playing a game. I then decided to test the current coming from the power switch before it even gets to the regulators. That read as ~700mA. This confuses me. Would this mean the power regulators are stepping the 9V to 5V at 100% efficiency? I expected this number to be much higher and closer to the 1.2 Amp spec of the AC adapter. I thought that its possible I might me misunderstanding something fundamental about how current works.
