L
legg
Hmm....
I further surmise that the failure of Q1 doesn't explain the failure of
the 8.2 Ohm resistor, because even with its specified maximum beta of
40, the switching transistor wouldn't pass enough current to burn out
the resistor.
The implication is that some other event has done for the both of them,
but surprisingly not destroyed the switching transistor.
<sigh> I thought I'd understood the sequence of events, but clearly not
Sylvia.
In the self-oscillatin flyback, base current is supplied
regeneratively by the feedback winding, to provide over-drive for
saturated switching. Beta is assumed to be somewhere between 4 and 12.
Note that the drive connection is drawn across the EB jn, so fusing of
the resistor would not turn the switch off - the voltage on the
emitter and base terinals could then be quite large - popping locally
connected parts like Q1.
Some re-examination of the actual board connections and further
examination of the feedback section (usually not very elaborate) may
offer further insight.
RL
