Ultrasonic Sensors
rgondzur
My need is to monitor the perimeter of an outdoor area.
I am considering ultrasonic sensors to act as an intrusion monitor.
They need to be mounted near ground level.
I need a device similar to what I see on upper-priced automobiles that
indicate the presence of items around its perimeter.
I have seen a very nice system mounted on the bumper of a BMW that
works extremely well to indicate a person walking around the vehicle.
The sensor must be designed for outdoor/external applications.
There will be a series of sensors with patterns that overlap to provide
detection around the entire perimeter.
They will all be wired to a controller that will sound an alarm when
the perimeter has been entered.
Perimeter size can vary from one hundred to several hundred feet.
Since they will be used outdoors, what will the issues be?
Therefore, I am looking for low-power, reliable sensors and the
suggested controller to manage the system.
Of course, price will be a determinig factor.
alarman
Where do you people come from?
js
Stanley Barthfarkle
Constant false alarms
What you are proposing requires "dual photo-eyes". A type of infrared
invisible beam detector. Around $300 for a good set, 1 set for each
perimeter side. This is not a DIY project.
Crash Gordon
Belgium?
Should we tell him that he's already in the thousands of dollar range
without seeing the job?
| js
alarman
Crash Gordon said:
Belgium?
I think we just did.
js
Robert L Bass
True. Also, ultrasonic detectors don't have anywhere near the gentleman's
requested range.
A type of infrared invisible beam detector. Around
$300 for a good set, 1 set for each perimeter side...
Outdoor photobeam detectors start around $135 for a 500 foot DS model.
IntelliSense (Honeywell) makes a 250 foot, single beam, outdoor
photoelectric that retails for $122.
Although not exactly what the gentleman asked for, Optex has an interesting
photoelectric that s designed to mount on the outside wall of the home,
providing protection for a row of windows. It retails for $125. There are
numerous other reasonably priced options for outdoor protection.
That depends on the DIYer. Most people have no interest in installing their
own security systems so for them it's not a DIY project. However, those
with a modicum of tool skills and a bit of patience can DIY install a
system. It's not rocket science. Photoelectric detectors consist of a
transmitter and a receiver. The devices require (at a minimum) 2-conductor
wire to the transmitter and 4-conductor wire to the receiver. Each needs to
be mounted on a sturdy post, fence or wall. An alignment light is clipped
to the transmitter, pointing in the direction of the receiver. The DIYer
then adjusts the lens at the other end until a spot of light coming through
the lens rests on the sensor. The alignment light is then moved to the
receiver end and the identical procedure is followed to align the
transmitter. This all takes a few minutes.
The hardest part of installing outdoor photoelectric motion detectors is
running the wire. Most of the time it's run below ground. A tool called a
"ditch witch" can cut an 18" deep by 2" wide trench for wire burial (be sure
to use cable that is rated for direct burial and check with your building
inspector for recommended depth of the trench to avoid damage due to ground
frost in winter).
Good quality photobeams properly installed will remain aligned for several
years unless they're impacted. When they need adjustment you take out the
alignment light and repeat the procedure above. Periodic attention to
insects and cleaning of the lenses will keep them running for many years.
Speaking of insects, I like to douse a small piece of sponge material with
Raid and leave it inside the detector, then seal all openings with caulk or
RTV. That generally keeps even outdoor detectors bug free for years. Any
time you service the unit squirt a little more Raid on the sponge. Be sure
the sponge is not in direct contact with the lens or the circuit board.
I sell outdoor photobeam detectors as well as lots of other alarm, CCTV and
automation systems online so I'm a bit biased in favor of DIY -- just as
many of the posters who install this stuff for a living are biased against
DIY. :^_
Robert L Bass
Bass Home Electronics
4883 Fallcrest Circle
Sarasota · Florida · 34233
941-866-1100 Sales & Tech Support
http://www.bassburglaralarms.com
Robert L Bass
Keep guys away from her. :)
Teenagers tend to be much too resourceful to be stopped by an alarm system
when there's a girl involved. :^)
Robert L Bass
Holger
Come back to planet earth.
Ultrasonic technology was used in the '80s with limited success. We are all
using Passive infra-red, microwave, or a combination of both.
You need to contact a local dealer and see what is available in your area.
http://www.alarmland.com
Bob Worthy
"Robert L Bass" > wrote in message
frost in winter).
Not to mention underground telephone, cable lines, electric, sprinkler
systems, electric and anything else that might be in the way, when an
unexperienced person grabs ahold of a ditch witch. Can be a dangerous tool
for the novice. Be Careful If You Choose To Use This Type Of Machinery. Call
For Locates. There are companies that will do the locates for you. Then if
you hit something they will be responsible.
Stanley Barthfarkle
Call
Unless you hit an a/c svc line with a walk-behind trencher.... if so, your
widow will be responsible for finding out who was responsible for locating
the services. ;-)
Bob Worthy
the services. ;-)
I bet that would do wonders for the business end of the trencher too. Might
knock off a tooth or two.
Stanley Barthfarkle
Might
Yep. In another life, around 87-88, I did aerial and underground line
construction for a Cencom cable contractor (Cencom eventually became
Charter)
One of our crews hit a 3-phase line with a large Ditch Witch 3500 rider, and
it literally blew large rocks and pieces of dig chain out of the trench up
to 75 ft. away. Luckily, the operator had the good sense to jump as far as
he could off of the trencher onto the ground. Would have killed him for sure
if he had stepped off of it. Didn't hurt the trencher at all- new chain and
it was good to go.
Stanley Barthfarkle
After they unwelded it from the 3-phase?
The chain looked pretty gnarly when it came out of that trench. Operator was
relegated to shovel duty for a long time afterward... "I didn't see that
Locate...really."
Bob Worthy
Charter)
it was good to go.
Robert L Bass
There are companies that will do the locates for you...
They're called utilities, as in electric power, CATV and telephone
companies. They don't charge for coming out to locate their wires for you.
There's a page in the front of most phone books with the heading, "Call
Before You Dig".
trencher....
Found a lot of high power cables less than 36" below grade, have you? Power
companies lay their lines deeper than the trencher can reach.
Robert L Bass
Robert L Bass
One of our crews hit a 3-phase...
--- snip fiction about previous life ---
Here's an image of a Ditch Witch 3500:
http://i9.ebayimg.com/03/i/07/0a/21/d6_2.JPG
This is a typical walk-behind unit:
http://www.ditchwitch.com/dwcom/Product/ProductView/100
The 3500 is an industrial unit. The walk-behind models I've used don't seem
to be listed on Ditch Witch's website though they're still to be had at some
(not Taylor) rental places. If you choose to use one it is certainly wise
to "call before you dig." Every equipment rental place I've ever dealt with
has instructions to that effect and most will happily supply you with the
phone number to call (in many places there's one consolidated 800 number for
the purpose).
Robert L Bass
Bob Worthy
"Robert L Bass" wrote in message
Before You Dig".
Thought you had me on "ignore" Robert.
The utility companies do, phone and cable don't on their laterals. But then
we always have the DIYer that gets tired of digging and burys romex, or if
he is real cheap, that lamp cord, out to his new Home Depot light post. Or
maybe he needed to add that extra circuit for his Christmas lights out in
the middle of his yard. He hardly got more than 12-16" down. Never consider
the obvious do ya! You just never know what the last guy did. I loved the
DIYer that had a speed bump in his drive way. The PVC went right across with
asphalt over the top. Of course he was proud that he got it over there with
such ingenuity.
Crash Gordon
Or..non-lethal..but way more expensive to fix is a fiber optic bundle.
is
called
| > a
| > sure
building
| > ground
| >> frost in winter).
tool
| > Call
if
| the services. ;-)
Crash Gordon
They call it Blue Stake out here and the service is free...they mark
everything in purty colors...gas/electric/telcom/etc.
you.
| Before You Dig".
| > trencher....
Power
| Regards,
| Robert L Bass
