Hi ,
I need some advise regarding compliance testing done by UL. We are intending to design a biomedical device ( an EKG machine) . And we want UL to do compliance testing aganist the following standards
1. UL 60601-1 (2006)
2. IEC / EN 60601-1 (1998+A1+A2)
3. ANSI / AAMI ES60601-1 ( 2005+C1+A2)
4. IEC EN 60601-1 (2005/2006 + C1+ C2) ( Europe, CE)
5. 60601-2-26(2002)
I have no information about the testing methods or what kind of test UL will perform on this device. I do not know about reasons that they can use to reject the device.
EKG machine:
1. Operated by UL approved 3.7V, 1A, LiIon battery. Battery can be charged by a UL approved charger. But when the battery is charging, EKG machine will be completely shut down by software. I am using the following "power connector"
http://www.digikey.com/product-search/en?lang=en&site=us&KeyWords=cp-065b-nd
Is this connector a good choice?
2. I am using the following box
http://www.okwenclosures.com/products/okw/ergo.htm
I do not know what should be the ingress ratings of the box and flammability ratings. Any advise!
3.
I have gathered following knowledge so far about the tests
1. Single Fault Condition : I am not able to find any clear answer for that. Can anyone give a simple to undertsaned explanation?
2. Ingress rating test: do not know how will they test
3. EMC test
4. Enclosuer mechanical robustness test.
What other tests should I keep in mind before we start designing this machine.
Jess
5. 60601-2-26(2002)
EKG machine:
3.
3. EMC test
Jess
