Current mirrors and compliance of output
Can someone tell me the equation to find the compliance of output please? Im missing one of my lecture notes. Its for a simple current mirror configuration.
Also can someone confirm that for Output current with early effect is:
Iout = (Iin / 1 + 2/B) x (Vout - VBE / VA)
Thanks in advance
Your equation cannot be correct:
1) you need to set parentheses to group terms in nominator and denominator of the fractions. As you write it common rules of evaluating equations apply (operator precedence). For example (Vout - VBE / VA) implies that you first evaluate VBE/VA and then subtract this from Vout. Which is impossible since VBE/VA has no dimension (units cancel), but Vout has a dimension (unit Volts).
2) Even assuming the parentheses were set as needed, the result of the right side of the equation is without dimension, but Iout needs a dimension (unit Amperes).
Both your questions are answered in detail here. http://users.ece.gatech.edu/mleach/ece3050/notes/bjt/bjtmirr.pdf
with explanations how to arrive at the results.
Harald
