I was probing voltages on the pins of the TVs Logic board (going to the Time-Control Board) and suddenly it came to life!
The power supply did not sound healthy to me, but maybe I'm mistaken.
I'm trying to get the video uploaded to listen to the sound it makes.
After I power cycled the TV it was was dead once again and I could not reproduce the probing that brought it to life.
Specs:
Vizio LED TV E70u-D3 (70")
Info PDF https://support.vizio.com/s/article/E70u-D3-Model-Information?language=en_US
Original Problem:
It was reported to me that the TV became increasingly unstable.
It would turn itself off after just a few minutes, and there was distortions on the screen.
Finally the TV would display nothing at all.
The power cable was replaced, and the TV was power cycled. Both attempts seemed to correct the problem, however now the white power LED will illuminate for a few seconds and go out after a minute, there is no longer any display shown on the screen.
Trouble shooting Technique.
I intend to check all the power supply capacitors, then move to stand by power, voltage regulators, and voltage levels on other boards.
The red label "12.3V" is the pin I was probing when the TV came to life.
With the TV plugged in, but in stand by mode, there is 0volts on these pins, however after the power button is pressed 4/7 of them get 12.3 volts.
I was checking this when all the sudden the power supply booted up (noisily) and the screen lit up.
I was able to feed a signal into the TV, and it displayed it just fine (just a noisy power supply to my ears)
The 2nd photo shows my diagnostics of the Power Supply.
Pin 13 labeled "PS-ON" has 0 volts in standby mode and 5v when the power button is pressed.
The voltage is persistent on this pin, however the "power" led only stays lit for about 5 seconds before fading out. After witch you can again power it on for a brief time.
I am not sure if the power supply quality is the underlying issue, or if there is a fault on the main logic board.
Can anyone suggest how I can test this?
Thanks!
Specs:
Original Problem:
Thanks!
