Andy
Hello:
I would like to build a simple 1:1 galvanically isolating transformer,
for insertion into the 75 Ohm TV antenna path, for the band between
45MHz and 870 MHz.
There is a design available at
http://www.epanorama.net/documents/groundloop/antenna_isolator_building.html
but it uses a ferrite core. The core materials that I've come across are
not rated for more than 200MHz, so I have some doubts about the design.
Would a coreless winding work? Any help with the choice of the core
material, L, compensation network would be appreciated.
Thank you.
45MHz and 870 MHz.
Thank you.
