I would like to erect a tall antenna to tap into the Earth's atmospheric e-field potential relative to ground. Theoretically, this can be hundreds of volts per meter. The process is also known as "ion harvesting".
What I had in mind was a 20 meter length of cable with pointed spurs or wire grid at the top hanging from a tree or building. At the bottom there would be a HV rectifying diode, with sensitive measuring instruments between that and an electrical ground stake.
This is purely for small scale demonstration and not to power ES motors, charge cap banks, etc. Practical uses include storm prediction.
Questions:
Does the cable need to be shielded between top and bottom? For example in the form of grounded coax full length or single wire on insulating standoffs. Even a wood pole becomes conductive when wet.
Is a single diode sufficient, or is there a better way of maximizing accumulated voltage potential? However, please note that this is not a tuned circuit. I am not targeting specific technological frequencies but rather the natural atmospheric DC potential.
Any general insights on this topic would be most welcome.
Questions:
