Regarding transformers, is the scribbling on the attached page correct?
J John Smallberries May 6, 2015 #1 Regarding transformers, is the scribbling on the attached page correct? Attachments turns ratio.jpg 60.1 KB · Views: 130
davenn Moderator May 6, 2015 #2 very difficult to read there's plenty of info online if you need to check your formula Dave
ramussons May 7, 2015 #3 Yes Voltage and current ratios have Linear relationship to turns ratio Impedence ratios are "squares" of turns ratio.
J John Smallberries May 7, 2015 #4 So, can we say that the impedance "follows" the voltage? Last edited: May 7, 2015
davenn Moderator May 7, 2015 #5 John Smallberries said: So, can we say that the impedance "follows" the voltage? Click to expand... no the impedance is relatively fixed .... do you know what impedance is and how it is calculated ? Dave
